cart was running fine till i went over a speed bump. now the cart is totally dead. Solenoid wont even click. Thought maybe something wrong with key switch wires since they have been spliced and reconnected in the past by previous owner . I get voltage through Brown and R/Y wire but not R/W. checked the 10amp fuse and was good. and getting voltage through fuse, checked diodes one was 622 and the other was 634
G14 quit running
I think you're on the right track looking for a bad connection.
If the diodes check out, the power for diode B comes from the accelerator micro switch.
Do you have the wiring diagram? You need 5 posts to view them, if that's a problem for you I can email you the diagram.
Posted earlier by wrsp View Postcart was running fine till i went over a speed bump. now the cart is totally dead. Solenoid wont even click. Thought maybe something wrong with key switch wires since they have been spliced and reconnected in the past by previous owner . I get voltage through Brown and R/Y wire but not R/W. checked the 10amp fuse and was good. and getting voltage through fuse, checked diodes one was 622 and the other was 634Regards
