Hello, new guy here. Just picked up a 2019 Tempo and looking for an original club/ball washer (part number) that slides into the mount. I have 2 coolers mounted and need only 1. Thank you
Club/ball washer
Posted earlier by RGerhardt View PostThank you, I’ve seen that one. The one I thought I needed just slides down into the bracket.
Posted earlier by GolfCartGuru View Post
The original ball washer utilizes a different mounting bracket to avoid being pulled up and out during the ball washing procedure, a scenario the engineers thought might happen if the V-shaped cooler bracket were employed
No such thing I’m afraid, the only option they had that fits into the cooler slot was the sand bucket. You could consider reaching out to a 3D printer to have a custom bracket made using the cooler dimensions if your application requires a universal option. Otherwise it would be easier to remove what’s there and swap it for the oem ball washer bracket and maybe cover the existing screw holes with some clear silicone wiped flush.
This gallery has 2 photos.
Golf Carts Forum
