92 club car seats
  • 92 club car seats
    What is the best type of wood to redo my club car seats with?
    It's likely you'll want to balance cost effectiveness, strength, durability, weight, and heat resistance. While wood is traditionally used, alternatives like composite materials might work better than wood in some cases because they're tougher, don't rot as easily, and need less upkeep.
    Pressure treated pine emerges as a cost effective wood type. Its treatment process creates resistance to rot and decay. For increased durability and heat resistance, cedar stands out. While slightly pricier than pine, cedar boasts natural oils that provide excellent protection against weather, decay, and insects. Additionally, its thermal properties enable it to withstand moderate heat exposure making it suitable for gas carts. Although cedar requires occasional maintenance such as sealing, its durability justifies the investment.
    When fixing seats on a budget, starting with cheap, lightweight 3/8" plywood is a practical way to go. If the seats require handrails screwed into the base, beef up that thin wood with a metal brace or go for 3/4" plywood so it holds up. Since plywood may not boast the same ruggedness as the alternatives, treating it with seal coat can bolster its durability against moisture and decay. When you're applying the seal coat, remember to layer it up and not leave any gaps, especially along the edges. Make sure every bit of wood surface is covered up nice and tight to fend off any moisture trying to sneak its way in.
    For gas carts: Nailing a heat shield to the underside of the plywood base can provide an effective solution for heat management. By affixing a heat shield made from automotive grade aluminized steel, you create a lightweight barrier that deflects and dissipates heat away from the seat area. This not only helps with comfort during the summer but also contributes to prolonging the lifespan of the seat base. Overall, while plywood may require occasional upkeep and may not offer the same longevity as premium materials, its affordability combined with the addition of sealant and a shield offers a pragmatic approach to redoing your club car seats while staying within budget and weight constraints.
