How do I reset OBC on a 2002 Club Car 48v DS, that does not have a Run/Tow switch? My Power Drive 2 charger will not come on even though I have 47.5v on short 3rd "sense" pin on charging port. Has my OBC failed?
Resetting the OBC without a Run/Tow switch requires a slightly different approach. To do this, disconnect the negative battery cable and press the pedal for around five seconds. This action helps discharge any remaining power in the system and resets the OBC.
After this, reconnect the negative battery cable and observe if it solves the issue with your Power Drive 2 charger. If the charger still fails to turn on despite adequate voltage at the charging port, it might indicate a potential problem with the OBC or the charger itself.
