Hi ,I have a 1994 Club car with the ignition switch in the on position and the F/R switch in the forward position when I press down on the accelerator the solenoid clicks but the cart will not go forward...when I change the F/R selector to Reverse the cart goes full speed in reverse without doing anything...Help please!!
reverse but no forward
when I place the F/R lever in F and push up on the first switch lever(the one that's on the left of photo) the cart moves forward... pulling my hair out now!http://www.golfcartsforum.com/attach...68-1-.jpg..:-(
the switch with the black and white wires is for half speed reverse(black has resistor). the attached wiring diagram is for a 92 but is the same. check the f&r switch wiring to motor and controller and check all connections. could be bad connection in f&r rotor and rotor contacts. Also could be a problem with the wiper switch/speed control.Attached Files
i used your picture... what i have in the manual.Attached Files
