2004 Precident wont move. solenoid clicks/but only rocks and solenoid clicks off
  • 2004 Precident wont move. solenoid clicks/but only rocks and solenoid clicks off
    Hello, my club car just died, the solenoid clicks, the cart rocks and then the solenoid clicks off. I replaced the solenoid. waiting for a new controller and speed sensor. Any other thoughts?
    Thanks Rob
    Ah the classic solenoid click and the cart doing the electric boogie without actually moving - quite the show! You've already made the solenoid switch, which is usually the first suspect in these scenarios. Kudos for diving into the controller and speed sensor next.
    However, considering you're still stuck, let's ponder a couple more things. Have a quick glance at those battery connections. Loose or corroded terminals can sometimes play hide and seek with power. Also, peek at the cables and make sure they're not worn or frayed, especially around any bends or where they connect. If all looks shipshape it might be that the batteries need to be properly load tested.
