I am about to purchase a 1994 club car, don't know much about it yet but I am wondering if any has any thoughts on switching from six 6 volt to three 12 volt marine batteries.
6V to 12V
Swapping from six 6 volt batteries to three 12 volt marine batteries is a common conversion in some cases. It can simplify the battery setup and might offer benefits like reduced maintenance and easier replacement down the line.
However, before making the switch, consider a few factors. Firstly, ensure the 12 volt batteries you plan to use are deep cycle and have sufficient amperage and voltage ratings to power your Club Car adequately. Check the dimensions as well, as they should fit within the battery compartment properly.
Keep in mind the wiring modifications required for this change. You'll need to reconfigure the battery connections. Having a wiring diagram handy would be beneficial to ensure a smooth transition.
Golf Carts Forum
