g2 wont start, big misfire! flames out the carb. checked flywheel and woodruf key is ok. all wire check out good grounds too. any help?
g2 misfire help
replaced coil, plug, igniter, cleaned carb. ohm tested pickup (ok) woodruff key on flywheel is good. all wiring looks ok.
still misfires! I hooked up my timing light and it is strobbing supper fast! like 6-8 times faster than it should... full advanced spark? only thing I haven't replaced is the pickup. could faulty wiring be suspect. It sparks like this with the new and old parts...
yeah right! user error.... and what auto tech degree led you to that diagnosis?
For anyone who actually cares about fixing there cart with a similar problem my findings are that the ground circuit has a short to power somewhere, the ground fuse gets blown when you press the accelerator and then the ground circuit runs around 8 volts grounding thru one of the components. this in turn causes a ripple threw the ground circuit and to the igniter. Which makes a very fast and week spark. you may think this is a bad ignitor, its not! find the short and problem solved. fix that matti!
