G9 runs then stops
  • G9 runs then stops
    I have a G9 at a cold start up will run 100yds and then it quits running (no spark at all its getting fuel and air just no spark) and it right at a 100yds ever time it like a invisable wall it just quites but if you let it set a minent or 2 it will start up and it will go 10ft and quits .The longer you let it sit the farther away it will go,
    I have replaced the coil and the voltage regulator and that did not fix it so whats next to look at ?
    It ran fine for years intill my lovley kid ran it through a big mud puddle and its all been down hill from there. Thanks kids
    Sounds like a blocked fuel vent or fuel filter. Try loosing the gas cap and see if that helps, if not change your filter.
      bad ingtor ok now
        Glad to hear you got it fixed and thanks for letting us know so others may learn from your experience.
          My columbia par car had the same problem. I did a few tests and read your fix. Ignition module was the cure.
