I have a '96 "Tuff 1" EZGO GXT-804D. I had trouble starting it and solved the problem by replacing the vacuum line to the fuel pump. It was clogged with an light brown oily sludge. I also noticed that the same sludge puked out of the fuel pump at some point through what looks like a vent port. I'm wondering which end of the line the sludge came from and how do I prevent it from happening again. Thanks.
Oil sludge in vacuum line
Not sure about the sludge part. But I've seen oil get into the line because to much oil was poured in. If the cart has been lifted, you have to measure 1.5 quarts of oil. Oil sludge is usually cause by oil being in too long. I would change the oil, clean, the oil filter and then measure out the oil to put back in. I would use a thin oil at first to help flush the crud out, then change it again after a few hours of run time. Then I prefer synthetic oil, it helps prevent dry starts, its sticks to the valves better, the engine runs cooler and quieter. I would even go ahead and replace that vacuum line.
Posted earlier by blake80 View PostNot sure about the sludge part. But I've seen oil get into the line because to much oil was poured in. If the cart has been lifted, you have to measure 1.5 quarts of oil. Oil sludge is usually cause by oil being in too long. I would change the oil, clean, the oil filter and then measure out the oil to put back in. I would use a thin oil at first to help flush the crud out, then change it again after a few hours of run time. Then I prefer synthetic oil, it helps prevent dry starts, its sticks to the valves better, the engine runs cooler and quieter. I would even go ahead and replace that vacuum line.
I haven't had one of those engines in my cart in a while now so let me think about it now that you say that. I know there is a crank case vent tube that goes to the intake box that will pull oil into the intake box. Hmmmmm. I'm thinking lol
Posted earlier by blake80 View PostI haven't had one of those engines in my cart in a while now so let me think about it now that you say that. I know there is a crank case vent tube that goes to the intake box that will pull oil into the intake box. Hmmmmm. I'm thinking lol
Posted earlier by cesolo View PostThen oil could get from the intake box into the intake manifold? Hmmmmm. That might explain the small oily spot on the air filter. Should the dipstick be restamped on a lifted cart to prevent overfilling? I can't tell if this cart was lifted by the manufacturer or aftermarket.
And to answer the thread question, it sounds like a mixture of old oil and too much overfilling.Regards
Those are air cooled engine, so in theory there shouldn't be any water in there at all. Of course there is that freak chance that rain water or water from washing may have gotten in there. If that be the case, inspect the oil fill cap and valve cover for any cracks.
Posted earlier by blake80 View PostThose are air cooled engine, so in theory there shouldn't be any water in there at all. Of course there is that freak chance that rain water or water from washing may have gotten in there. If that be the case, inspect the oil fill cap and valve cover for any cracks.
just from experience, I know one thing oil and water make brown sludge, I'm sure there are other combinations also.Updated by gaminde; January 20, 2012, 10:08 AM.
Posted earlier by gaminde View PostI think its a lot less chance of freaky, you could go through a puddle, tall wet grass, mud, creek or washing My dog pees on my cart! and the problem is in the vacuum line and vacuum lines suck. any vacuum leaks will suck.
Posted earlier by gaminde View Postand the problem is in the vacuum line and vacuum lines suck. any vacuum leaks will suck.
After thinking on this I think its a combination of things, overfilling the oil allows oil where it should not be, as the oil sits where it should not be it collects moisture thus brown color. So clean it up blow it out! rawhide.
