Oil in filter box and white smoke out exhaust?
  • Oil in filter box and white smoke out exhaust?
    What the heck is causing this, it is actually running bad because of this!
    Welcome to the forums! What kind of golf cart do you have?
      Oh yeah! It's a 1992 Ezgo Marathon 295 cc
      Thanks for the quick reply!
        Sounds like the common signs of a worn engine in need of a rebuild. Run a wet and dry compression test to check out the rings.
          taylorP if you ever change the rings OR the seals, make sure you do them all at once. Usually if you do one thing it will throw off the other. Just a tip hope this helps.
          Thanks,
          -BR
