I have a ez go golf cart with a robin engine. It turns over but won't start.It seems like it dont have any compression. Can anyone help
96 Ezgo Robin Engine
Posted earlier by barden.brian@yahoo.com View PostI have a ez go golf cart with a robin engine. It turns over but won't start.It seems like it dont have any compression. Can anyone help
- compression
- spark
- fuel
- use a compression tester and check the amount of compression in each cylinder. Should have around 120-150psi.
- check for spark by removing the spark plug, keeping it plugged in and holding the end to a ground and turn the engine over you should see a blue spark
- if it has all of the above, spray some starting fluid down the carburetor and see if it runs, if it does then you have a fuel problem.
