hi am new to this i fix golf carts part time and i am usually pretty good at it but this g1 is giving me real trouble it keeps blowing fuses as soon as you put them in i have used a test light with one end one the gound battery post and the light lights up as soon and u touch the frame but i can not find any bare wires if you have any ideas please help could it be a problem with the starter as well
Yamaha G1 blowing fuse
I had the same problem and it drove me crazy trying to find it. Mine was a small wire along the fender from the solenoid that was rubbing the fender. The fender had a crack in it allowing it to flex which rubbed the back of wire. You couldn't see the break in the coating of the wire but I had moved it around enough looking for the problem that it started working then when I touched the fender it would flex and blow the fuse, that is how I actually found the short. Mine was blowing the fuse on the ground side.
