My golf cart is an EZGO gas with custom lift kit (see picture) I'm having trouble lubing the front end main shaft on both sides (see other picture) I don't know what to call this shaft, but the picture should explain what I'm talking about. . These shafts won't take any grease. I've removed the zerts and cleaned them, but still not able to force any grease into the shafts. Anybody have any tricks for how to get grease into these shafts without removing them?
having trouble lubricating front end
Hey rbdaves. This is a great question, I am happy to help! You must replace the zert with a brand new one. After you purchase a new zert, if it still does not take grease then you must take apart the joint and clean it out completely, then re-assemble it and lube it until grease starts overflowing out of the end joints. Relube once every 2 weeks, or sooner if you ride in the dirt and mud.
P.S. I do know a trick to get the "clean" the joint with out removing it, but it will require purchasing special tools which will cost about $30-50.
Mike Eddie.Updated by Michael Eddie; April 28, 2014, 11:20 AM.Regards
Thanks, Mike
Do you know what kind of an engine might be in my golf cart? It doesn't have any labels on it.
Mike writes: " I do know a trick to get the "clean" the joint with out removing it, but it will require purchasing special tools which will cost about $30-50."
What might these tools be? I'm in an RV Resort with a shop full of tools.
Thanks.
Posted earlier by rbdaves View PostMy golf cart is an EZGO gas with custom lift kit (see picture) I'm having trouble lubing the front end main shaft on both sides (see other picture) I don't know what to call this shaft, but the picture should explain what I'm talking about. . These shafts won't take any grease. I've removed the zerts and cleaned them, but still not able to force any grease into the shafts. Anybody have any tricks for how to get grease into these shafts without removing them?
- 1 like
