1994 Gas what type oil for engine and differential?
  • 1994 Gas what type oil for engine and differential?
    Was given a 1994 cart that would not start,converted over to HIE ignition now runs fine. I need to replace oil in engine and diff. if someone could tell me the types required. thanks, RAY.
    10-30 in the motor, aprox 1 1/2 qts and 90 wt in rear end
      Thanks PP, I will use those types.Ray
        Um you are going to want to run SAE 30 weight GEAR OIL in the rear. This rear has a sling system that tosses oil up to lubricate the upper gears. Fill through the rubber plug hole on top until it comes out the check hole (13mm bolt, second one up)
          Thanks MATTI. I had noticed that the diff oil was much thinner than 90wt but thought someone had added engine oil but it smelled like gear oil.
