2007 EZGO Oil Change
  • 2007 EZGO Oil Change
    Hello I am new to this forum, and would like some info on changing my oil for my 2007 gas 2 cyl EZGO. I do not see a filter?? How difficult is it to change the oil?? Service wants like $74...seems like a lot to me...any advice would be appreciated...Thanks
    the oil filter is at the bottom of the engine on the clutch side i believe. it is a triangle with 3 10 mm bolts to take out, then you just spray it off with brake or carb cleaner & put it back in. be carefull to make shur the o-ring stays in place. hope this helps. pistol
      also it takes about 1 & 1-2 qts of 10-30
        Great, I found what appears to be what you are describing...thank-you, ...now is there a drain plug, or do I just remove the filter, and capture the old oil from there?? Thanks in advance for your help!!
        Updated by Jakel; March 3, 2012, 06:57 PM.
