First, remove the spark plug ground wire and unscrew the spark plug. Now insert the spark plug back into the ground wire. Finally hold the tip of the spark plug against a solid metal ground and attempt to start the engine. If you see a spark that means your golf cart has spark. If you do not see a spark try again with a new spark plug. If you still do not see a spark, that means your golf cart has a spark problem.
How To check for spark
Recent Posts
