79 g1 yamaha no spark
  • 79 g1 yamaha no spark
    we got a 79 g1 with 2 stroke with no spark
    we have tried following all wires from a diagram and they all are were there are sposed to go from what we can tell
    when we connect the bottom 2 wires on the cap part of the genorator a1 n a2 i belive....the whole cart is now a positivly charged we cant ground anywhere but the battery and it shows it has 11.7 volts with an ohm meter
    the black wire comming from the motor behind flywheel was burnt we replaced the wire but dont know where to hook it up to..
    and once and a while when we turn the key it makes the motor spin WITHOUT pressing the pedel
    thanks for any help in advance
    Anyone we are stumped with this
      Hi camaro, you have to be sure that it is wired up right. Do you need a larger diagram? If it runs when you turn the key on, check the pedal switch and the micro switch. Since they are what throw power to the solenoid when you press the pedal.
        Well we triple check and the wiring is right and it still has positive charge to frame
              Anyone?
                i have the same problem. i am taking 2 carts and making one when u turn the key on engine starts turning. all wiring is good still looking for a short or something
                Updated by potater03; October 12, 2010, 07:28 PM.
