my 1980 yamaha golf cart will start and idle but when you give it gas it will do nothing more than idle. Could it have a automatic feature that when you get below a quarter tank that it won't allow you to run it dry or is this a carb problem?
1980 yamaha golf cart starts but won't run
No automatic feature, to run you need gas, compression and spark. If you are missing any of them then the cart will not run. You can take some 2 cycle mix and pour a tablespoon of it into the spark plug hole, replace and try to start again. If it starts then you know that it is a fuel problem. If it does not then check for spark and compression.Regards
