2001 TXT EZGO got a little wet
  • 2001 TXT EZGO got a little wet
    2001 TXT EZGO got a little wet - water got up to the floor boards after running into the lake - replaced Solenoid but my charger doesn't even flinch when I plug it in - runs kinda funny too, stalls out when I press the pedal all the way to the floor - any suggestions ?
    That poor poor cart
    It seems as if when you press the pedal to the floor, the batteries cant keep up, this could also relate to a controller issue. How long has it been since your last charge, and were the batteries covered in water at all?
      2001 Ezgo Txt
      Matt - yep - the cart took on a little more water than it could stand - the cart was fully charged prior to the accident, the batteries are new as they are less than a year old - only the bottom of the batteries got wet. I agree, I think it is the controller too, is there any way to reset the controller ? Are there any fuses in an EZGO ? Should I remove the new Solenoid, disconnect all the batteries and start from scratch to see if that would correct this issue ?
