Hello, I have a 91 36 volt ez-go. I've done some searching on here and see the pot should read 0-5k ohms. What leads do you test to read the resistance? I replaced it several years ago and think it's bad again, but I would like to test i with a multimeter. It's jerky and stops pulling after half throttle. Thanks in advance.
Potentiometer
I think potboxes are about $100 or so. Unless you can find one locally or someone who has free shipping you're kinda stuck.
Here's where you test your pot box:
Click on photo to enlarge.Attached FilesComment
Thanks Doug, Should the wires should be unplugged when the test is done? Or does it matter? I have mine off the buggy at the time. I found just the pots only online for around $42 including shipping, just have to remove them from the box and solder them back in, anyone ever heard of doing this?. Thanks again! Donald....Comment
