Ezgo wont go
  • #61
    grandson drove it all day and it did fine thnx again now its time for a paint job!
    • #62
      Shew that was a relief!
      I saw where you posted again and I thought Oh no what happen! Glad it's running OK.
      • #63
        Well, I've spent a lot of time reading you guys and I got my cart running with all the information you guys shared here and I sure do appreciate it but I do have a couple questions if you ain't too busy.
        My solenoid has a resistor connecting the large terminals and I'm not sure what it's for. The used control box I put on it didin't have one but I went ahead and intalled it anyway.
        Secondly, my fnr switch isn't like any I've ever seen... I was wondering why it might be different. It isn't a toggle or a cam switch. Just a three position switch. The switch also has some type of resistor connecting two of the terminals. Can ya'll shed any light on what the resistors are about?
        • #64
          The one on the 2 big terminals is for the closing of the solenoid so it doesn't arck.
          The little one on the 2 smaller terminals is to keep it from back feeding it's a diode should have a white band on one side. This should be + coming in to it off key switch.
          • #65
            Thanks alot... You've been very helpful... The pro mechanic at the golf cart shop checked it out and decided my motor was bad but I suspected that it wasn't because I parked it when it was running fine, plugged it in and the next day it just didn't work. I know very little about golf carts but given that the control box had kind of a melted look to it... With my brilliant deductive powers being what they are and all... I was suspicious... Rocket science, right? Not so much. But I didn't have a clue how to start the troubleshooting process but you fixed that... Some of my leads had questionable connections and I think that may have been the culprit, so I replaced them all... so, Thanks again.
            • #66
              Here is a good article to read about them from Alltrax.
              http://www.alltraxinc.com/files/Doc1...ns-Learned.pdf
              This may help you to understand the workings better.
              • #67
                Good info there Andy. Thanks for posting.
                • #68
                  Hey gang, new to this forum but have had carts for a while.
                  My current project is an older Western Golf 36v with a Curtis 1204 controller.
                  I've just installed new batteries, which I assume I've done correctly. I'm getting 40v on charge and about 38 when first installed.
                  Problem is, the cart won't run. Solenoid clicks, but Im not sure how to test it.
                  I get full voltage (38.6) with key on, F/R in forward, and pedal depressed (across B+ and M- on the controller).
                  Positive and negative across the solenoid only show 28.9V and go to 0 when pedal is depressed.
                  Did I wire something incorrectly or is my solenoid bad?
                  Thanks!
                  I'll post up pics of the cart tomorrow when the sun is out. I've had her since the day she was born....many moons ago. Serial # 1000719141
                  Updated by KismetLRC; July 28, 2012, 11:27 PM.
                  • #69
                    Sounds like you don't have the solenoid wire correct.
                    • #70
                      Solenoid wires haven't been changed since it came off the factory line in 1989. Nothing around the engine, controller or solenoid has ever been touched.
                      Could I have wired the batteries up incorrectly to have this happen?
                      All appear to run In series.
                      • #71
                        Here's the voltage off of the solenoid. When the pedal is depressed, the voltage goes to zero.
                        What's the small black box here with voltage going to the solenoid?
                        • #72
                          Right side battery wiring. Negative going to charger inlet doesn't show up too well
                          Left side
                          • #73
                            Here is the schematic for it.
                            Check the micro switch and see it it's passing the voltage through.
                            • #74
                              I've seen that and all appears to be good. Is there a schematic of the solenoid?
                              I'm concerned about the low voltage across the posts. This is a 4 post WR solenoid. 26V doesn't seem right.
                              Any other thoughts?
