I have a 94 medlist the solinoid clicks but no move ment. just put new batteries in was running fine have power to motor all four lugs in reverse or forward seems odd
Ezgo wont go
Man if you give details like this it's a lot better. Spinning wheels with a heavy load like that! You burnt the motor out of it more than likely are the controller are both.
I'd say you fried it. Check the F/R contactors and see if they are all burnt up. I'll be surprised if they aren't.Comment
To add to that, when you are checking voltage on an electric cart you need to check at the battery. Electric carts do not use the frame for any electrical connections including the ground.
If you want to take the time to diagnose and have some patience we can probably walk you through it.Updated by dougmcp; January 27, 2012, 07:12 PM.Comment
Sorry for my post earlier but details like that are how we figure out what happened to it.
I will help you all I can but you have to be forth giving of info when you want us to help figure out what happened. We need as much info as possible if you want a good answer to the problem.Comment
Jack the cart back wheels off the ground and put a cable on the 2 big terminals and then try it. If it works the solenoid is bad.
Just because it clicks doesn't mean much.
Another test take a volt reading on the small terminals one with key off and one with it on and see if it's passing voltage.
Make sure all the cables are good and tight. Pull on each one of them good. If they are good and tight then a good pull want hurt them. If they are loose are fixing to come apart you will find it.Comment
Assuming everything is good to the controller you can test this way:
Key on, F/R in forward, throttle depressed.
Measure voltage on the controller from B+ to M- if you have no voltage the controller is bad.
Here is a schematic of the controller:
Click to enlargeComment
They do store energy so the small arcing is normal.
Your manufacturing code on your cart indicates it is a 1994 cart.
The number on it is not an Ezgo PN or anything I am familiar with.
Can you post a photo of it? Is it black or silver?Updated by dougmcp; February 11, 2012, 03:04 PM.Comment
Ok Andy got it cleaned and hooked . Battery pack, Neg toB- and charger
Pos to solinoid right large post and charger.
B+ to 12 0clock F/R and solinoid left side large post
B- to Battery pack Neg solinoid right small post
M- to motor A1
S1 motor to F/R 3 oclock
S2 motor to F/R 9 oclock
A1 motor to M- on controller
A2 motor to F/R 6 oclock
solinoid with small post toward you
left large postB+ F/R 12oclock
right large post Battery pack pos. and blue wire to F/R
they have a diode or restor going from left to right small and large post on solinoid
Small left postred wire to 1 on controller red wire to F/R
Small rightBlack wire to B- and another wire into harness
that about does it i just have to hook up the pos and neg to battery pack upon your ok !Comment
