I have a 2012 club car president that I am adding a light kit too. The head light has a 48 to 12 volt converter. The bucket harness has a 12 pin connector . This does not match the harness from the headlight. Light has a 6 pin connector with a adapter to connect to the converter. Headlight does work but im unable to connect the tail lights.
Light kit wiring
Posted earlier by Dlperezjr58
Thanks. I was hoping there was an adapter cable I could use.Comment
Posted earlier by cybercart
So in 2008.5 cc stopped including the bucket harness on their precedents, and the tail lights need a timer relay wired n so you can continue to use the parking brake without the lights being on all the time. Do you have any specifics on the light kit brand / links / pics you can provide?Comment
Unless you buy a complete kit you may be forced to perform some splicing, I am attaching a guide with all the basic installation info, if you are wiring in a 48 to 12 reducer, that would need to be wired directly to the batteriesAttached Files
This gallery has 1 photos.Comment
Posted earlier by cybercartUnless you buy a complete kit you may be forced to perform some splicing, I am attaching a guide with all the basic installation info, if you are wiring in a 48 to 12 reducer, that would need to be wired directly to the batteriesComment
