I want to put a lift kit on a 94 ezgo is it wouth the extra money to go 6" or more?
how much of a lift kit is good
Posted earlier by dougmcp View PostDepends what you want to do with the cart, the lift may be just the beginning.
What do you envision as a completed cart, where will you drive it and what kind of terrain will it be on?
Is your Ezgo gas or electric?
Its gas and mostly its just a campground runner I would like to make some trail for carts with it. So I know I need some tires. My nephew had adaptors made by the local school for free so he can use 4-wheeler tires I may do the same.
Gas carts are pretty forgiving when they are lifted so you shouldn't have too much trouble. If the terrain you are using it on is not too extreme, a 3"-4" lift should be fine and the center of gravity remains low so the cart is more stable.
Posted earlier by tspeed View PostThanks Guys
I think getting to a point where I can use ATV tires is plenty and they are easier to come by with good tread. The off-camber thing is important there is a good sized hill where we are...
Lifts look good but they really are unsafe the higher you go. The rock crawlers use a width and lots of wheel travel up and down. You want the center of gravity to be as low as you can get it. The draw back on width is most trails are narrow so it becomes a problem with going to wide also. I have seen long travel carts not make a trail because of the narrowness in betwen tree's.sigpic
I'm here to help!
