first off its a 2 stroke gas not sure of the exact year.Ran fine last year when I put it away.Stable was added,fogged the engine removed battery.Went to go get it ready for the season put a fresh plug in fully charged battery and nothin.Checked for spark and there is nothing.Replaced the coil with a new one still nothing.What should I check next?Thanks for the help.
No spark
Thank you. I don't think it will magically loose spark after sitting indoors for the winter. Are you getting fuel? Is the spark plug wet? Is the motor spinning over as strong as last year or is this charged battery weak? Did you hook up the battery right? Plus on plus, minus on minus?Regards
Posted earlier by hoot View PostWell I called a dealer and he told me you cant test thr ignitor,said you can only replace them.Also said they discontinued the one I need but there is one that will work with a little wireing.Regards
