Why am I loosing seals
  • Why am I loosing seals
    Hello all, I have an 89 ez go with a 2 stroke robin engine. I did a total rebuild on it new piston cylinder crank and bearings and new seals. I put it all back together and lost the seal on the fan side. I put a new seal in and with in minutes the thing was leaking again. when I turn the motor over exhaust comes out of the seal. Why would there be so much pressure in the case to blow out the seal??????
    Hello, clean everything, the crankshaft end, everywhere around where the seal goes and the new seal itself. When you get the new seal, install it evenly by covering it with a piece of wood and tapping it with a hammer or by using aluminum stock and tapping it with a hammer or ask EZGO about their seal installation tool.
    I think that you may be installing them incorrectly, that is why they are blowing so quick.
