the threads inside my clutch are stripped and i don't know how to remove the clutch.help please!
ezgo clutch removal
I have had this work before, but requires removing the motor unless you can get enough clearance between the frame and clutch to swing a hammer. Cut a couple of 2X4 about 12" to 15" long as a wedge, wedge them between the clutch and crankcase going opposite or each other. Insert a long 1/2" bolt or rod into the clutch. Using a hammer on the bolt you should be able to pop off the clutch. It is also possible to use a wheel puller if you use a spacer inside the clutch. Hope it works.
