I have a 2000 EZGO 2cyl that runs fine most all season. It will run fine for 4-5 holes, and then just not start at all. I'm not sure if its a coincidence, but it has done it a couple of times in the past after I fill the tank. After several attempts, choking, etc it will kind of sputter and begin to run fine again. Any suggestions would be greatly appreciated. Thank you.
2000 EZGO runs fine and dies
I live in the midwest and do leave the car over the winter for 4+ months. This problem happened last summer and again this spring on my 2nd or 3rd tank of fuel. Its odd, it runs good otherwise.
Does the coil assembly just quit when they are bad or can it be intermittent, maybe after it gets hot and once it cools again it starts and runs??
Posted earlier by unplayable View PostI live in the midwest and do leave the car over the winter for 4+ months. This problem happened last summer and again this spring on my 2nd or 3rd tank of fuel. Its odd, it runs good otherwise.
Does the coil assembly just quit when they are bad or can it be intermittent, maybe after it gets hot and once it cools again it starts and runs??Regards
I think it is the coil/igniter. Last night it would not start again. I pulled a plug off and no spark. I tapped on the coil with a golf ball and the spark reappeared and it ran fine again. I think I'll try a new coil. I'll post the results. thank you.Updated by unplayable; May 3, 2011, 07:38 AM.
