wiring question 36 volt admiral motor
  • wiring question 36 volt admiral motor
    does any one know i got a hold of a admiral 36 volt motor but on back theres a black round disk with 3 wires coming out. red, green,and balck,I have no idea what these are for or were they go? any help thanks
    The wires are for the speed sensor.
    This is a sepex motor. I'm not sure what cart you have but if yours is a series motor this is the wrong motor for the cart.
      Is this motor off of a Yahama or Ezgo, Club Car uses advanced or GE and it would be sepex if not it may be used for tac output (I think Yamaha)
      also club car does not use sepex on 36 volts how about a better picture and label info
      Updated by gaminde; February 18, 2012, 07:30 PM.
        That would be sweet to find a 36 volt Sepex motor HMMMM
          found some sales BS
          Exclusive golf cart motors for Club Car DS 48-Volt Non-
          Regen Electric Carts (10 Splined Axles), E-Z-Go 36-Volt
          Non-Regen Electric Carts (19 Splined Axles), and Yamaha
          36-Volt Non-Regen Electric Carts (19 Splined Axles).
          New in 2008! Motors for Club Car High Speed IQ
          Regen (10 Splined Axles) and E-Z-Go PDS.
          • Can be used with OEM controllers (add a 400 AMP
          controller for increased torque... see page 91).
          • Gain up to 8 MPH additional speed with a 5-10%
          loss of torque.
          • More efficient than the leading motor.
          • 1 Year Warranty.
            and free freight with a $3000.00 purchase
            orange motor below
            http://www.albiongolfcars.com/images/cat_07.pdf
              Its A Ez Go 2000 Txt Pds
                sorry I know nothing about ez go or txt or pds
                most likely series 19 spline ???? someone school me on this
                  If it's a PDS it's 2000 or newer!
                  correct and the motors will fit on any EZGO rear end from mid 90's up. But as stated it's a spex motor. The PDS model carts will have the senor wiring on them.
                  You will need to find what wire is what to splice into the PDS senor wires. You should have a 4 wire connector that plugs into the controller that runs back to the motor.
                  You are going to have to figure out which wire on the new motor is which.
                    FYI
                    Red = 12 to 20 VDC from controller
                    Black = Ground or neg from controller
                    Green = Hall Effect output +5 VDC pulsed output
