wide open throttle
  • wide open throttle
    hello all,
    1997 elect. club car. throttle is wide open. thought it was pot. it checked out at 0-5k which i think is correct. i can even unplug the triangular shaped plug with 3 conductors in it that comes from the pot, and as soon as the microswith closes it is wide open. all wiring appears to be correct according to diagram. any ideas? could it be the motor speed controller?
    I will look over the schematic a little later today
    What cart do you have exactly regen?
    Updated by gaminde; June 1, 2013, 03:14 PM.
      Not sure. It does NOT have the rocker switch for forward/reverse. It has a lever for the forward/reverse switch. Also it does NOT have the tow/run switch. The accelerator speed control has a microswitch wit a rotary pot with 3 connections. Does this help?
        I guess a little, sounds like a series motor with a forward reverse lever
          yes, i do think that it is a series, and yes it does have the lever fo forward/reverse
