My 95 48v. Club car runs well but melts battery cables and terminals. All connections are tight. Any suggestions?
Melting battery cables
Posted earlier by Larry1950 View PostAgree.
What gauge are the battery cables? Are you melting all or just one. Are the battery and cable connections clean? Something is drawing way too much current.
Wow! The connection at the positive must be corroded and or loose. Is the solenoid getting hot? I would make sure all connections at the batteries, solenoid, controller, OBC are clean and tight.
I take it the Negative cable going to the OBC is melting. According to the wiring diagram the negative and positive are located very close to each other at the controller, make sure the wires are not loose or touching and are tight and clean
http://www.golfcartsforum.com/attach...ng_diagram.jpg
