Won't charge
  • Won't charge
    when I plug in my charger, the charger hums for a few seconds and then trips the breaker on the charger. Any suggestions on what the problem may be?
    Most likely diodes
      Also use a hydrometer and check every cell in your battery pack before replacing anything.
        What exactly am I looking for when I check the cells. And if it is the diodes, where are they and how do you change them?
          Your going to need a hydrometer from the auto parts store, you suck up a small amount of acid from each cell and there is a float inside that you read a number off of its called specific gravity.
          but most likely it going to be diodes inside of the charger either a 2" square thing about 1/2 inch thick with 4 wires or a strip of aluminum with 3 wires going to it.
          do a google search for checking diodes depending on what you have.
            ok thanks
              ok, I used a different charger and The needle pegged all the way over on the high side and then if popped the breaker after about 3 or 4 minutes. On my charger the needle stays all the way at the bottom and it pops the breaker after about 10 seconds. Any ideas on what I should look for now?
                Put an automotive charger on each battery one at a time for 3 of hours each.
