I don't plan to lift my cart but wanted some feedback on what looks better over the stock 8" wheels, 10's or 12's? Anyone have pics of there non lifted cart with either size wheel?
10" or 12" wheels
It's all a matter of taste between 10" and 12" wheels.
The least expensive and most readily available is the 10" wheel with 205/50-10 tires. The other size is the 12" wheel with 205/30-12 tires.
Tire diameter not wheel diameter is the deciding factor in replacing tires on a cart.
Your cart, like most, comes with 18" diameter tires and the largest size you can install without a lift is 20" diameter.
Think about looks vs ride quality, the larger Your cart probably has 18- 8.5x8 tires which are 18" diameter, 8.5" wide on an 8" wheel. Increasing the wheel diameter and maintaining the tire diameter makes the tire sidewall shorter and will have a rougher ride.
Here is a stock 8" wheel/tire combo:
This is a 10" with 205/50-10" tire:
And finally a 12" with a 205/30-12" tire:
I run my cart on 10" wheels with the 205/50-10" tire and it is a pretty good compromise.
It's not a Precedent but here is a photo of my cart with the 10" wheels:Attached Files
Your cart came stock with a 0 offset (centered) and will easily take a small offset without problems. There larger the offset, the more likely it is to hit the fender while turned to full lock position, especially when hitting a bump.
Normally golf cart wheel offsets are stated by the width and distance from center in inches.
Example I have 7" wide 10" diameter wheels on my cart that have an off set stated as 3+4 which is from the hub centerline, 3" inside and 4" outside.
Here is a pictorial to explain wheel offsets:
Posted earlier by erict View PostI see that some 10" wheels show a 0 offset and -25 offset. What does this mean and will they both work on a stock non-lifted cart?
Thanks Doug. Here is the wheel I am looking at.
http://trademarkcarts.com/product/65...e-tire-lpstp10
Would the last wheel offset above (8" 4+4) be considered 0 offset since it's centered?Updated by erict; September 27, 2011, 12:16 PM.2005 CC Precedent
Posted earlier by dougmcp View PostYou are correct. In automotive terms it would be zero offset, in golf cart wheels it may be termed as a 4+4 offset.Updated by erict; September 28, 2011, 10:48 AM.2005 CC Precedent
Just a heads up, if you are planning on ordering wheels, BU has a 1 week only free shipping deal going on now.
They are the largest in the industry and should be able to get any wheel you want but you may have to call them.
Here's the link to the free shipping coupon: http://www.buggiesunlimited.com/landing/FS-1005FS.asp
I seem to remember you were looking at a wheel like this:
Updated by dougmcp; October 5, 2011, 10:07 AM.
Posted earlier by dougmcp View PostJust a heads up, if you are planning on ordering wheels, BU has a 1 week only free shipping deal going on now.
2005 CC Precedent
