G1A drive belt width?
  • G1A drive belt width?
    Hi all - can somebody tell me what the proper width of a drive belt is for a G1A? Measured at the widest part of the belt (the top).
    Thanks!
    Scott
    Hey Scott,
    The drive belt should measure approximately 1 3/16". A used belt will still work around the inch area.
      Thanks Matti. I'm pretty sure mine is smoked. I'll go measure it now. I'm pulling a 490lb snowmobile with it, and it doesn't like to start with the load when it's hot. A skinny belt will cause an overdrive condition and make it hard to start.
        Posted earlier by scott_nadeau View Post
        Np. Hope this helps solve your problem.
        If you aren't already... especially with towing, keep an eye and make sure that the rear always has enough oil :biggthumpup: Just a tip to keep your $ pockets $ happy in the long run
