Solenoid Problems ?
  • Solenoid Problems ?
    I have a G14 that won't go, EZ orvotherwise. Power is going in to the solenoid but not out. replaced solenoid but same problem What else can I check
    Ed B
    Hello Ed! When you press on the gas, do you hear a click?
      Solenoid
      No I don,t here a click, I replacewd the solenoid and still no click. I get a reading of 12 volts on input but no output.
      Ed
        Run a 6 gage wire or a pair of jumper cables from the + on the battery to the solenoid's red terminal and press the gas. Does it start?
          Solenoid
          Thanks for reply, I'm not sure what you mean by the red termina, does that mean positive? If so no click no nothing and no start. Maybe it's something else
          Ed B
            Did you wire up the solenoid correct, there is a wiring diagram in the diagrams section to check. There is also a switch near the foot pedal you should check too.
