It will idle down , but will not shut down. Checked accelarator shut off switch with meter and it's working. have to pull battery cable to kill motor.
G9 engine won't shut off
With the throttle released, the stop switch should go 'open'. When this circuit opens, it should remove the voltage from the Red / White wire going to the Ignitor Unit and the Ignition coil. (as well as the starter relay)
If they are still getting voltage, and the stop switch is good and adjusted properly, it sounds like something must be miswired.
When did the problem start?
