reversing buzzer
  • reversing buzzer
    Hi, as you can see by the posts I have only just purchased my cart and I am trying to fix some of the problems therefore can someone tell me where the reversing buzzer is located as mine is missing or disconnected.
    Thanks, Phil
    Hello Phil, I assume it is the G9... The reverse buzzer is mounted on the driver side wheel well. Make sure it is there, then locate the fuses mounted near the reverse buzzer. One fuse is for the buzzer, the other is unrelated, check the fuse and replace if necessary with a 10 amp fuse. Common problem on these carts.
      Thanks Matti
        very nice
