Shockers
  • Shockers
    Hi all, how dificult is it to change the rear shockers on the g9 cart. Do I need to remove panels or can they be accessed without doing this. I do not want to start the job only to find out there is an easier way
    Phil
    I would say if you had access to a lift, it is quite simple. I wouldn't think the body panel needs to be removed. But I never had to do them on a G9 before.
      Posted earlier by philb View Post
      Phil
      shockers? the rear body is not at all difficult to remove on the g2/9s and its probably a good idea to do it so you know how.Youll have access to everything including the shocks. I didnt even put the fasteners back in when I had a g-2, just put the body on and it never came off.
        Thanks guys,
        I will see if I can do it without removing the body but if not it does not sound like a big job.
        Phil
