my cart blows the ground fuse as soon as you install fuse.also the carts frame and starter are all hot.if you check with a test light just setting there it has voltage on it.i have removed all wires a checked and repaired couple wires it smoked at the fuse.any suggestions .
g1 blows fuse
Here's the wiring diagram for your cart, I upped your account so you are able to view it. http://www.golfcartsforum.com/golf-c...g-diagram.htmlRegards
Posted earlier by shannon79malibu View Postis there a ground that goes to the frame. because the wire that blows the fuse is ground to the frame beside the battery.also the case of the generator is 12 volts just setting there. is that right?Regards
