Wet battery's
  • Wet battery's
    I have a newer Ezgo 36 volt cart with 6 Trojan battery's and the tops of the battery's are always wet .i now have them in the basement and they are leaking when not being charged .they are all at 6 volts . I tested the moisture with baking soda and it did foam . When I top them off when they are low I make sure I don't over fill .i have had the cart for about 8months and they have always been like that . What can I do to fix the problem .
    Thanks Frank
    only add water when the batteries are discharged. If you add water when they are charged they will be overfilled.
      Ok thanks I will do it that way .
