Have a 1990 EZGO 36V two seater, and can't seem to find the lube point for the rear end. Cart has sat for 5 yrs, and is dry so would like to add some lube before I have dammage... Anyone have a pictue...?
Newbie needs Service help
Jack it up and the drain is the fill hole also. If you look on top there should be a vent plug. U can take it out and fill it form there but it takes awhile.
The bottom diff cover has the indition in it is all you need to fill. You can drop the cover plate off and real carefully replace it with lube already in it.sigpic
I'm here to help!
