Battery Cable Supplies and question
  • Battery Cable Supplies and question
    I am wondering if this cable is ok to use for golf cart battery wiring. The price doesn't seem to bad, if it is acceptable.
    http://www.ebay.com/itm/4-GAUGE-Mari...item5d31e149f1
    I would appreciate any input. i want to buy parts to make my own battery cables. Awhile back Doug gave me a tip on a place called Spectro Wire, but there website is jacked up. I emailed them telling them i wanted to place an order, and never got a response. So I am looking elsewhere.
    i live in the desert, and haven't found a welding supply close to me.
    i want to buy 4 gauge battery cable, and also the copper lugs that you can smash onto the wire.
    I think Doug had said they were 5 / 16" terminals .
    Updated by redman34; January 26, 2012, 07:48 PM.
    Looks OK for the voltage but you need to know if it will handle the amperage of the cart and the add doesn't say.
      What is a typical amp range for 36 volt and 48 volt stock carts?
        I'm not sure of the strand count on the ebay cable and it seems too cheap to be a high strand count. Normally this stuff is $1.20 to $1.50 a ft.
        Try Cameron Welding Supply
        Palm Desert, CA 92260
        (760) 837-0404
        Connections from the cable to the lug are not smashed on (but I like the way you you described it )
        They are put on with a proper swedge tool or soldered (this is a pretty important connection).
        You could also get cables from a local forklift repair company.
        Try White Crane
        45524 Towne St, Indio, CA 92201
        (760) 347-3401
        You can buy cables with ends on them through ebay in any length you like.
        Here's just one example: 10x16" cables for $48
        Link: Ebay battery Cables
          Doug that a good link. I think I'll order some stuff.
          Thanks!
            Posted earlier by andy4639 View Post
            Thanks!
            Yup, I found these almost as cheap as I could make them and easier than building them yourself.
            Updated by dougmcp; January 26, 2012, 11:34 PM.
