I have a Model X440-23. That won't move. The batteries are good. It doesn't even make a noise when I push on the peddle.
I need help with 36v ez go
Welcome Chuck, I moved your post to the Ezgo section.
Check your battery pack voltage, should be around 38v.
Check your battery connections for clean and tight.
Do you get a back up beep with ignition on and in reverse?
If not check the reed switch and ignition switch.
If yes, check the solenoid by jumping the large posts with a 6ga wire.Updated by dougmcp; July 9, 2011, 12:07 PM.
