I replaced the batteries on my 2000 Electric Club Car. It charged the first time, but now it goes to about 15 for a few seconds and kicks the breaker on the front of the charger. The cart runs, but seems like it won't charge.Any suggestions?
2000 Club Car New Batteries, runs, but won't charge
I went over all the batteries. I disconnected them all then reattached them the way the diagram shows, positive to neg etc... with a positive on #1 open and a neg on #6 open. I then hooked the cart positive and negative to where they should go. Now the charger turns on and hums as if charging, but the needle does not move off the zero. Now what have I done.
ok here I go again. I replaced the fuse and same result. When the charger is placed on the cart it drops to the left end then goes up to zero and sits there as it hums. So I borrowed a friends charger and same results. It has to be the cart, right? I ran over the wiring diagram again and it looks rights. i checked the fuses in the cart and they don't look broken. I have rebooted the computer to see if that helps and nothing. Is it time to take it somewhere or do you have any ideas. The batteries are reading around 8.
sounds like the obc now. It is strange though I hooked the charger up last night and this morning it was off. Maybe I have been over-reacting and the new batteries are causing this difference. Don't know. If it gives more trouble I am going to look at the obc and see if I can by-pass it. Any thoughts?
