here is the deal i have a 2002 club car 48 volt i charge the battery full charge ,the cart will go about 1/8 of a mile and the cart will slow just about to a stop like the batterys are dead,so i charge the battery and check the battery at full charge with charger still hooked up and battery show 14.4 to 14.7 and all four battery show good,but when you ride the cart 700 or 800 feet it is like the battery are gone could this be the speed controller over heating and stopping the cart,need some help here, thanks crush
2002 Club Car Will Not Run Long
The problem you are describing sounds just like a problem with one of the batteries, it is harder to find out on higher voltage batteries. Your batteries are under 3 years old?
Try the above from my last post again, and this time run the cart until it starts slowing down and check the voltage on all batteries.
While you are at it, check the water levels in the batteries. Also make sure there are no broken battery or motor cables by looking and tugging on them, and that the connections are clean and tight.Regards
