I had a 400 amp alltrax controller on my 98 club car. It burned . so i bought a 300 amp alltrax controller is not programable. Now my ohms the pedal reversed.
Ohms on gas pedal are reversed
Check the wiring harness connected to the controller, ensuring that the throttle wires are correctly oriented and connected according to the manufacturer's specifications. Reversed or crossed connections could cause the pedal signals to be misinterpreted. Since the new controller isn't programmable, verify the compatibility of the wiring harness and connections between the controller and the throttle system. If there's an option for throttle input configuration or adjustments on the controller itself, ensure it's set correctly for your Club Car's setup.
Golf Carts Forum
