last night I plugged in my 99 club car and when I awoke in the morning, the white reset switch had flipped. I took it for a ride, but noticed that it was lagging. any ideas?
club car does not wanna take an charge, what am I doing wrong??????
I had the same problem last year, turns out it was due to a falty circuit breaker in the charger.
There are two versions of this charger, remove the top cover and check if the reset switch says (made in USA).... this is the first version.
If it says that then you need a new charger.
The second version was made in mexico and has a stronger and better circuit breaker. Hope this tip helps. -
hi, new here but if you can you might want to try your charger on another cart to see if it works and if it does than the problem is with the cart a 99 is it a 36 volt or 48 volt?.........................................
TomTom
if i didn,t like them so much i wouldn,t touch them...........Comment
