It’s rare that I run into anything I can’t fix as a mechanic but this really makes me scratch my head. The main problem started out as a no spark issue, at this point it would turn over just fine. so i did some minor testing and ultimately decided to replace the coil and pickup coil. I should also note that I changed both spark plugs as well. Now we are in spec, still no spark. So now I moved on to the igniter, so I replace that along with the voltage regulator for good measure. No spark, but I will say now all of a sudden the reverse alarm works. Scratching my head and decide, hell money isn’t an issue I’ll replace the solenoid while I’m at it. Now it won’t even crank. I’ve checked my connections, and grounds. Depress the pedal and all I get is a click at the solenoid. I’m confused
2001 ezgo txt no spark/ won’t crank
