352 Robin. New coil, plug, fuel pump. Starts and runs great, but dies out after about 10 minutes, and will not restart. Wait 10 minutes, starts again and goes, but for not as long. Very frustrating. Any Ideas? Is this a common problem? I couldn't find any threads on it. Thanks.
2007, gas, dies when hot, after about 10 minutes
Wish I could answer that then I would know what's wrong with mine! But mine is a 1986 Robin 244cc 2 stroke and it will run fine for 20-30 minutes then it will either just act like you turn key off or if you stop it will turn over got spark gas let it sit for 15 minutes it will go again and so on and so forth put 2 carberator on it fuel pump new fuel line even put insulation around fuel lines just put new secondary clutch on it today done with working on it this week got to take a break from it
hope you have better luck than me!
Check rev. limiter. Its hooked into the coil. It can cause these symptoms. Remove the earth wire and start. If symptoms persist then the limiter is ok.
check for crankcase pressure dropping due to air or oil leaks, check hoses. Clean the fuel pump. After that I'm stumped.
